Well let's see, way to cold thank god for the heated shop. I've started back to work getting her ready for paint. The car is back on the chassis dolly, body is off the ceiling, and I have roughed in the fender wells on the front end of the car. These are times that I really do envy you guys that get to work with a kit. Having some of this metal work laid out for you must make this a little easier than trying to figure out, just how am I going to get this covered and how can I bend it this way. But I can get this stuff cleaned up and coated with the same stuff that the rest of the sheet metal is covered with.
Need to source the bulb-seal that I will need to go between the metal, frame, and body. With some luck I should be able to get the rest of the holes laid out that I need to cut into the body and start prepping it for undercoating. I can not believe how different this body is left to right. It's like they molded off of two different cars, guess that is what is meant by character.
Patrick
