MSD makes Black Caps for the small diameter billet distributors. BTW there is no reason for the center carbon to be disintergrating unless it is overheating. Check to make sure it is being contacted by the center spring blade on the rotor. Put a small spot of dielectric graese on the button and see if it transfers to the rotor blade after assembly, if not bend the blade a little farther.
Rick
