I took a period correct external regulator alternator to the local mom and pop auto electrical rebuilder and had him upgrade it to 95 amps. The cost was less than $100. It's a total rebuild, the case looks as new, and the amperage is way up over stock. For the regulator I took a modern solid state high capacity regulator, and on EBay bought an old points type regulator with a repro Autolite cover. I took the Autolite cover off the old style regulator and put it on the solid state regulator. Just an idea that I thought may help you. Good luck.
