Originally Posted by strictlypersonl
There's also the possibility of the opposite problem: an overcharging alternator. Put a voltmeter on the system and check that you've got 14.1-14.7V at 2000 rpm with a charged battery. Any more than that is not good.
And while you are at it, see how much voltage swing you have. A lot of fluctuation is bad. I would also check the distributor cap.
