El, with my Lakewood, TKO600, FE combo I use the Ford D0TZ-7515A clutch fork with a hole drilled in the end of the fork so the slave-to-fork rod distance can be easily adjusted (drilling that hole is a job for the machine shop, btw). Note that in my photo below that in order to get the slave to line up properly with the fork an aluminum spacer was used (probably similar to what RodgerH was writing about above). The D0TZ-7515A is available from RockAuto for less that $20.
http://www.rockauto.com/dbphp/x,cata...ATP_ZA101.html
