Old 01-12-2010, 04:13 AM
Default What size, rpm range and HP and Torque are you looking for?
Danr55 Dan If you have most the specs on your motor, Keith Craft is the one with the most custom made camshafts. He own the patterns for 25-30 custom grinds. He has small ones in the .530" up to 650" lift, Alot depends on what you are looking for. 110-114LSA on th cam profile. The wider the LSA the less nasty the idle and drivibility manners. I have a 482 motor with the old crane 587-607" hydro roller and fine this is the max you can go without getting higher pressure valve springs for over 6,000 rpms. I run mine to 6,200 max rpms. Big wide power band from 2,000 - 5,800 rpms. You will need new pushrods and get the correct length. Hydros are nice. Rick L.
