Old 01-13-2010, 12:07 PM
madmaxx madmaxx is offline
Slave cylinder leaking and not perpindicular to clutch arm. If you have a tko 600 get in to contact with greater cincinnati performance cars, bill sells a nice set up. The reason it is leaking is the push rod is going at an angle. You could just replace the slave every couple years, if you dont want too get it perpindicular and your leak will disappear.
You may be able to modify your bracket, that is what i did.
