Originally Posted by Doug I
Jay - by draining and then dropping the tank are you thinking that that could shake the sender loose from whatever it's getting hung up on?
You have to know/see about these senders to understand. You can swivel the position of the float arm so it does not contact anything. Also as Max points out it could need shortening.
A new sender is about $25 so it is worth the instructions it comes with to put a new one in.
