The interior will be black to begin with, unless I have time to sew up a new set to match the paint, but not too likely to have that much time before autorama.
Terry I will call you and come down to see what you got. I need to make it sooner than later.
UPDATE: 517 hours, 57 days down, 33 to go.
Doors are on, had to do some modifications to the hinges we made, but got them on and doors are lined up nearly perfect, will only need some minor glassing work for all the reveal lines to match.
installed the transmission tunnel cover in cockpit, got all the holes made large enough for the bumper spacers and rubber seal around them. got the brackets for roll bar bolted on frame, set the roll bar and down tubes. have to do some grinding out on body and then just a little filling to make nice holes with rubber trim.
Now I have to figure out what I am going to do for the door latches. I liked OFM's, he had a little knob to pull up on. It will most likely be just what ever i can engineer from stuff laying around the place.
that 33 days is looking scary since we are still most likely a week away from painting the body. If we can have it all painted within the next 13 days, that will leave 20 for assembly and to build the displays.
