Old 01-18-2010, 11:35 AM
strictlypersonl strictlypersonl is offline
That tank doesn't use a bladder. It just uses foam instead of baffles.
Call Nisonger for what the ohm range is for their early Smith gauges used in the CCX cars. Since that tank won't accept a swing arm, you'll have to use a tube-type sender if the current one isn't correct.
You realize that that tank (cheap!!!) is 10" deep?
