Old 01-19-2010, 12:47 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
B-Back of manifold, if you need a plate check my site.
I thought only the FEs had a space for the breather plate? SB manifolds have a fitting or need one drilled and tapped. My 289 Performer RPM uses the brass vacuum block for the crankcase vent.
= Si Opus Quadratum vis, angulos praecidere noli. =
