Old 01-21-2010, 06:43 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Originally Posted by cgilbert37 View Post
And 48 IDAs w/42mm venturis. (Yea, I've enlargened the float bowls and drilled for the 3rd progression hole.)
Thanks!
Cgilbert,
If you can I would start with 37 or 40 mm chokes. This will give you a stronger signal and make it easier to tune the carbs.
However, as for a baseline I would start with
60 idle fuel
100 -120 airholder
50 bypass
4.5 pumpjet
Do not worry about the main stack yet. get the idle circuit adjusted properly then move on to emulsion tube. This should get you up to 2000 rpm.
Next hurdle will be selecting you emulsion tube. What do you have on hand?
