Originally Posted by Nicholas Taylor
hi there
i'm in south africa and would like some help with a start point for my cobra with the chevy 350.
It has four Weber 40 DCOE"s. there is a flat spot between 1500 and 2000 rpm.
There coughs and splutters during cruising.
Any advice?
Nic
Make sure you have your throttle plates as closed at idle as possible without having the engine turn off.
Only concentrate on your idle circuit and make sure the carbs are synced.
