  #222 (permalink)
Old 01-22-2010, 02:43 PM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by dcdoug View Post
Did insulating the temperature sensor make a difference? Does anyone know if an uninsulated sensor gives lower than actual temp readings in cold weather, or does it matter because the actual sensor is inside the pan in the oil?
I currently have my oil cooler blocked off with lexan, but will probably install an oil cooler thermostat (still not completely decided on which one yet). The lexan didn't seem to do very much. But if insulating the sensor is a big deal, then I'd like to do that first and get a real baseline on where my temps are.
Thoughts?
Doug,
I think that the insulation cannot help but improve the accuracy of the gauge - especially in extremely cold weather where the front of the oil pan and thermostat fittings draw the most heat away from the sensor bulb.
- Fred
