First question to ask with the pedal pressure 5 to 10 times more than it should be is:
Pedal ratio?
What is the mechanical setup on the pedal to the rod? Is it as designed or has someone changed it?
The pedal should be pushing the rod no lower than 2"s below the hinge point. (I'll get the exact distance tomorrow.)
DV
