Thread: clutch set-up
Old 01-24-2010, 08:55 PM
dcs155's Avatar
dcs155 dcs155 is offline
Cobra Make, Engine: classic roadsters, .060 over 460
Hi Ed, just went out in the garage and as accurately as I can measure it appears from center of the pedal pivot to were the master cylinder rod is on the pedal I'm at 2 1/2" wich is prob not helping matters at all. The push is a nice straight shot with no binding but what is strange is that the first 2-3" of travel there is no resistance and all the pressure and clutch engagement is in the last 1" of total travel. Kinda like a on-off switch
It's been this way since day one and at first thought it was a bleeding issue but its bled properly.
I went thru my original paper work and the clutch disk is a mcleod #260273,pressure plate is a mcleod #360850 and the flywheel is a centerforce #700260. Is it possible that between way to heavy of a clutch and my pivot being off by almost 1/2" that would be causing this??? I really appreciate all the help and info as I'd like to fix this once and for-all. Dave
