Thread: Vaccum Readings
Old 01-25-2010, 08:45 AM
undy's Avatar
undy undy is offline
As the engine RPMs increase at part-throttle you're engine will be pumping much more air but your throttle plates will only be slightly more open, making the ratio (pumped air to throttle plate opening) slightly disproportionate. This will have a tendency to create more engine vacuum on an engine that doesn't produce much vacuum at idle.
Dave
Too many toys?? never!
