Old 01-25-2010, 10:05 AM
Voltaire Voltaire is offline
Cobra Make, Engine: B & B Cobra 5.0, Twisted Wedge-Trackheat, TKO 600
I had the body on my cobra painted body off which worked great. It allowed the painter to fine tune the body work and undercoat the entire body. Before I sent it to the painter I made fiberglass panels to fill the largest gaps. After I installed the body back on the frame I epoxied the panels in and used flexiable caulk between the fiber glas panels and the body. I also used close celled pipe insulation that has the adhesive where it is split to fill in the some of the areas such as between the passenger compartment and the trunk.
