Thread: Vaccum Readings
Old 01-25-2010, 07:52 PM
dreamer427 dreamer427 is offline
Default carb set up
ive got the same carb u got. mine was spot on. very few adj. but i know what wrong with yours.if u remove the rear float bowl pull the metering block off u will see 2 small set screws in the main body. remove them. reassm.carb set your idle mix screws at 1 turn.turn over carb set the primary plates at 20th idle slot is showing......see how that works.
