01-26-2010, 10:13 AM
Cobra Make, Engine: SPF#0760
As I remember, the mounting bracket(s) required for a passenger side bar (hoop) are not installed at the factory on all chassis. On newer chassis I believe the brackets were standard on the frame, but where the break on chassis # is I don't know. Any bar that you need to add new brackets for will not be as strong as the one with factory installed brackets due to the welding procedure. There is a tech paper on how to add a second bar but no mention of chassis #'s. But this project is not for the faint of heart. There is always the full width bar option too. Olthoff sells them. And a taller drivers side bar also available from Olthoff. I have his taller bar on mine.
SPFWiringDiagrams@Comcast.net
