dsc155 Dave if this clutch has floating weights?
This is the main problem for this clutch. If you want to do a test, pull the car apart down to the pressure plate and remove the ring and floating weights on the pressure plate, reassembly the car and go road test. tell me how the clutch works now. I am not going to say any thing to chnage your answer. If you can get the trans out you should have enought room to remove the weights and steel ring. Give us a reply after this is done, I will then tell you.......more info.
Rick L. Ps been there, done that,
Dave sent me a private e-mail with your number to reach you at in the evening.
