Thread: Side pipes
Old 01-27-2010, 01:01 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
I can build you a pair of highly polished, 304 stainless steel side pipes, for Cobras, Corvettes & Hot Rods. I sell them as a "Kit" because every car is a bit different, with engine type & size, motor mount location and body cut outs.
Notice how the collector and tail pipe turn out slides between the muffler and the outer shell, for a nice & tight fit and smooth transition. It then only requires a small tig weld.
I will never go back to mild steel and ceramic coating. These should last the life of your car. Polishing is quick & easy.
You can email or call anytime.
cobrakev@galaxycable.net
402-781-2322 (Central time, anytime)
Thanks,
Kevin
Regards,
Kevin
