Hi Dean & Larry
For those looking for a 427-W shortblock, and shipping is FREE in the US. Here it is:
M-6009-427F 427 CUBIC INCHES BOSS SHORT BLOCK
Retail $4,999.00
Jobber $4,699.00
In stock!
427 cubic inches
Boss 4-bolt main block M-6010-BOSS35195 – 9.5" deck height
Mahle forged aluminum 4.125" bore pistons with valve reliefs for Z304, N351, GT-40 and other inline valve Windsor cylinder heads. 17cc effective dish volume, check piston to valve clearance
.005" below piston to deck height nominal
SCAT 4.000" stroke forged steel crank
SCAT forged steel H beam connecting rods with floating pin
Hydraulic roller camshaft compatible
Neutral Balance rotating assembly
Recommended cylinder head fasteners M-6065-BOSS head bolts, M-6014-BOSS studs, or M-6014-Z304 studs, depending on application
Designed for M-6049-X306//X307/C3/D3/Z304DA cylinder heads. Not designed for production 302/351W or M-6049-Y302/Y303/X302/X303/X304/X305 cylinder heads
Assembled and ready for your heads, cam and timing chain set
Requires head gaskets M-6051-R351
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
