ng8264723 You have to remember that the fittings are smaller that the lines. The line my be 1/2" but the fittins could be 3/8" ID where the
oil comes through. #10 IMO is bare min. size for any 427-428 motor in a street car that gets a little abuse. Get into these 482 and up monsters, #12 with hiflow fittings. Remember every fitting cuts flow of the
oil down a little. I am going to #12 with next motor. What may be saving the motor in the car now is the 3 quart accusump that helps keep
oil pressure and flow up on road courses. I do also run high oil pressures too. Rick L. Ps if your car is drilled for #10 lines, see not problem with putting #12 lines in. You may have to install the fittings after the lines are run. Measure 3 times and cut once. Give a 1/4" extra after getting the correct length.
The lines don't stretch.
Rick L. Ps will the block to the motor take #12 fittings or #10's? My need to get new block. Hope the main port in the block was opened up for more flow.
