Originally Posted by Ralphy
If you don't mind me asking. What sort of spring rates are you guys running with four coil overs? Also are you running the same front/rear springs?
I will have to look up my invoice from the rear shock supplier and see if the rate is listed as I don't remember.
My front suspension is not the typical MGB. It's from Fast Cars in Michigan. and I don't remember what rate Ted from Fast Car supplied. I believe the springs may be color coded so I will take a look. The suspension is 80lbs lighter than the MGB so the rate would be different I'm sure to MGB.
