JHV,
A couple of things you can try. First is to remove your non adjustable and install a threaded rod, 3/8 all thread grade 8. I would see if your clutch is slipping as well, your clutch maybe getting worn. Or you can buy one of my setups and it would work perfectly with your setup. Take a look. I removed the boot to show the rod position.
