Old 12-20-2001, 11:02 PM
jdean's Avatar
jdean jdean is offline
Default Torker II Air Gap
I always liked the serious look of the Victor series single plan manifolds. But they are way too tall for most BBF Cobras.
So I did a lot of cutting a grinding on my Torker II to achieve a similar look. It requires the use of the sheet metal gasket that goes under the stock 460 manifolds.
I also got rid of the heat riser passage, so the incoming air will be cooler going into the cylinders - like the RPM Air Gap.
[IMG]file:///C:/My%20Documents/My%20Pictures/Torker%20II/FRmanifold/TIIAG.jpg[/IMG]
