Old 02-02-2010, 01:41 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
An inline oil pressure switch is a stock item at "Summit" or "Jegs" and I believe its pressure setting shut-off setpoint also has a few choices. Route your ignition thru it and shutdown is automated with loss of oil pressure. Don't use your electric fuel pump because the car will continue to run until fuel pressure is dissipated. The switch connects to the tap on the block used for the oil pressure line to the oil pressure gauge.
Regarding the "Bag of worms"...
Now you need an impact switch and a rollover switch....
SPFWiringDiagrams@Comcast.net
