Old 02-05-2010, 02:48 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
The instructions to terminate the ends (at the distributor) is to strip the wire back 5/8 inch and fold the bare wire under the metal terminal and crimp into place. Is there any tricks to make this connection easy and secure?
You can use something like this along with a vise: http://www.summitracing.com/parts/MSD-3503/ It works pretty well.
Something like this is even better though: http://www.summitracing.com/parts/SUM-900400/
I've used both types. Both make a very nice and secure crimp. The vise type is a bit less convenient though because you have to figure out the proper length for your wire and then get it over to your vise. With the hand held crimper, you can route the wire and make the crimp with the wire still installed on your car.
Chris
