Old 02-07-2010, 12:12 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
The input shaft leak was probably due to the bad Pbearing. Replace the seal on the tranny just to be safe.
TO remove old Pilot bearing =
Fill the hole with wheel bearing grease, pack it in to fill all the area, you are going to smack the tool with a hammer so the grease that is displaced pushes the bearing out of the blind hole in the crank.
If you have an old input shaft it works best but a metal tool for aligning the clutch disc under the pressure plate also works well.
Start the tip of the input shaft into the hole/pilot bushing. Use a bigger hammer to shock or hydraulic the bearing out of the hole. If it does not come all the way out fill with grease and repeat.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
