Old 02-07-2010, 09:46 PM
JUS BIT JUS BIT is offline
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
Most likely you have a mechanical pump mounted on the lower drivers front side of the motor if you have a Roush. Just follow the fuel lines from the carb.
You may also want to check to make sure that the fuel filter is cleaned out or replaced, especially after sitting for a bit. It could be clogging the pump or the floats.
Next, I check the float levels on both sides of the carb. If its a Holley, then they should be right at the bottom of the sight window. Check Holley website for more details on how to do this.
It may be possible that you have some trash in the carb. If thats the case, you'll need to remove the bowls and metering blocks, clean and reassemble.
Best luck, hopefully you will get it all back up and running good soon...
James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
