Old 02-08-2010, 04:43 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by 767Jockey View Post
Arthur,
I used Grade 8 bolts with Loctite to mount the diff to the frame, and I used the stock Jag threaded shafts for the coilover mounts.
I'm now thinking of using Grade 8 threaded studs in the diff. This may make locating the diff into the bolting plate easier. And, as I've moved the entire IRS back 3/4", it will eliminate the clearance problem I have with getting the two top forward positioned bolts into their holes.
Moving the IRS 3/4" rearward will also require custom (3/4" longer) length shock shafts/bolts. And I'm hoping that Stainless Steel would be a good option for the shafts. Trouble is, I do not know what grade steel was used on the original shafts.
Thanks for your info.
Arthur
