Wilf
Well said in the tradition of "size does NOT matter".
Only those short an inch or two would advance such a theory. In your case you are down quibbling over a meesly 1/4''. If that is all your are lacking, you are well within the acceptance of the BIG boys.
Thanks for the respects for my car. Now only if, I could command as much. Maybe if I put a big white stripe right down the middle of my.. oh never mind.
BTW. If you were able to walk up and measure your cylinders, that means the heads and the manifold are off of the car AGAIN. That is the problem with them small blocks. Bore and weld, bore and weld.
Good day!
Jamo
Do you owe Claunch money or something?
TURK
OBAMA IN in 2012
