Helefino. Canton pan, remote filter, cooler. I put a quart in the filter and put 5 quarts in the pan. No show. Two more quarts, it shows "Add 2." I run the engine a few minutes, add 2 quarts, run it again... still showing below "Add 1." I add the last one and let it go for now. Will check when it's cooled and stood a while. Actually, it has... hold on...
Oops. I'm up about a quart. A little drain is in order tomorrow. I should have waited a little longer after the second engine run, I think.
Jerry, the thermo has been on there for a while without having much of an effect. It might be because it's slightly overfilled.
= Si Opus Quadratum vis, angulos praecidere noli. =
