Old 02-14-2010, 07:13 AM
mikeforte mikeforte is offline
Hi Paul,
You have a stock cast iron flywheel. It is common for these cast flywheels to have heat cracks in them. They are cracks and should be fine for mild performance use. If you are going racing or drive it like a racecar (shifting at redline often) then I would replace it with a steel billet or lite weight aluminum billet flywheel. I sell & stock both flywheels if you need one.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
