Originally Posted by ERA Chas
Where is Euclid when you need him?
Uhhh, you don't need Euclid on this one. With Aviaid, 9 qts. means 9 qts. Rod, pull the drain plug, use your jack to tilt the car in the direction of the hole, let it drain until it quits dribbling, then if you put 8 quarts in the filler hole I bet your level on the dipstick will then be right on the "add one quart" line of your stick. Aviaid doesn't screw around with "system volume" and the like, nor do they confuse you with the quart in the filter, etc....
INITIAL OIL PAN FILLING AND DIP STICK MARKING PROCEDURE
We rate our
oil pans for static level in the pan. This is the quantity of
oil that will fill the sump up to about the underside of the hard tray bolted into the pan. We recommend that the 1st time you fill the pan in the car, with the car flat on the ground and the pan empty, you add 1 quart less than the advertised number of quarts and mark the stick. Add 1 more quart and mark the stick again. This is a high-low marking procedure. Then start the engine. Let everything pressurize and fill, shut the engine down, and let everything drain down for a few minutes. Then add oil to bring the level back to the top mark on the stick, noting how much oil is required to fill the pan back up to the top mark. The total of the added oil plus the initial fill will give you system capacity. This now includes lines, filter, cooler, whatever. From that point you can adjust level to suite your requirements. Some will run a little more, some a little less, depending on usage.
Source:
http://www.aviaid.com/pdfs/pan_dip_stick.pdf
