Old 02-17-2010, 11:39 AM
rustyBob rustyBob is offline
to answer your question of "do they build a good car?" yes
that being said it also depends on weather or not Unique actually
built the car or did someone else build it ???
if this car has the look and features you are looking for in a
replica then by all means check it out carefully and ask a lot
of questions as to who built it who maintained it and how it was used.
if the car has been sitting for some time and not maintained then it will
need some TLC to get the brakes,hoses,and fluids replaced and maybe
a new set of tires.......
if it has been driven on a regular basis then most of that stuff will
be ok for regular use if you keep an eye on it........
if the car has been run hard or raced in any form then you will want to
go over it with a fine tooth comb and check for leaks and cracks
and worn parts.
all in all you will want to check it out and see if it is what you really want
to get into and keep in mind your skills or abillity to maintain it yourself.
good luck and keep us posted on what you find............
and most important.......price......is it within your comfort zone.....
