I have a kart that we had fun with years ago. One of the classes of race karting is for the 5HP Briggs & Straton. There are tons of performance parts for them. Cams, heads, carbs, exhaust, etc. etc. Easy to build up.
Most people don't realize that the stock 5Hp Briggs & Straton engine is 205 CCs. A fairly big one cylinder engine. It is rated at 5 HP with the govorer on and limited to 3,600 RPM. Even with no performance mods but just removing the governor to let it rev, you will take it to 9Hp. With the right sproket a 9 HP stock Briggs can easily hit 80 MPH. With all the performance mods available, the sky is the limit.
The limitation with a kart like this and with most karts is that there is no transmission, so you are riding around in the equivalent of second gear. Moving the sproket ratio up or down gives you higher top speed but less low end and visa versa.
If you click around on the left side of this page you will see some of the stuff available for the 5 HP Briggs. And that is just from Competition Cams:
http://www.compgoparts.com/
