Old 02-22-2010, 04:01 AM
Default was there any grease on the input housing??
wrogers55 Wayne there should have been a thin coat of grease on the input housing. This help with sliding or movement of the throughout bearing, and also collect disc power from the clutch and help keep the grease on the housing over time. If you clean up the housing with emery cloth see how bad it is. I don't know the max and min size of the housing output diameter. There is a spec some where. I am sure you can also get the parts to repair this and do it self or have a shop repair it for you. I believe that the housing just slides on and off. Sealing the 2 parts is the important thing. Gasket or 24 hours with a RTV, GRAY. I use a coating of lubraplate, white grease that is water resistant and heat doesn't melt it unless real high temps. I will wait for the out come. Rick L.
