Moroso small block ford valve cover gaskets from Summit. Steel core with blue silicon, no leaks. Also used Moroso
oil pan gasket set. I had the old Canton pan that required seperate rail gaskets. Went to my Ford dealer and bought their Silicon gray gasket sealer for Diesel engines. Used it on the
oil pan gaskets. Again no leaks.
