Originally Posted by olddog
The coeffecient of thermal expansion is multiplied times the distance, so a longer block will grow more than a short one over the same temp change.
Absolutely true. Those with an aluminum FE block and aluminum heads, coupled with a solid flat tappet cam, actually have to set their valves to a
negative lash value.
