Hey there Merv, gauges are reading correct, have tested with auxilarry temp gauge fitted.
The`radiator is now out and going to be taken to radiator shop tomorrow, I still have teh original radiator (replaced due to split in top tank) and can see that the original has much larger tubes than the replacement, so it may be that the new one simply does not flow enough water.
Once again if that is the case there will be a cranky phone call to Adrad (they supplied with a 2 year no question asked warranty)
Cruising in 5th
