Originally Posted by timsullivan
For the pan gasket I would recommend the one piece gasket by Ford Racing available at Summit Auto. Just search for engine parts under 351W
I will agree on that.
Have be reusing one gasket 3 times, even on different blocks.
some small dabs of silicone in the corners and a couple along the sides of the enginge makes it possible to take oilpan off and on again without toutching the gasket....
Have also used Summit steel/ rubber valve cover gaskets with good luck.
Temted to try the Moroso items.
But; Summit items are very thick, and is probably why I can run full roller rockers/ high lift cam under standard (low) valvecovers....
RS
