Thread: ABS Power Brake
Old 03-03-2010, 09:45 AM
Roush #1's Avatar
Roush #1 Roush #1 is offline
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
I recently installed the ABS electric power brakes in my Lone Star LS 427.
They work well and I am pleased with them. They are a good alternative to those that don't have enough engine vacuum for normal power brakes.
I did have to send the master cylinder back as the original one they sent leaked internally the second day of operation. It was replaced promptly and it all works well now.
I would recommend you check your wiring before installation as I had a bad connection on a wire splice that was taped up when I got it. They had spliced a 10 inch piece of wire to lengthen it and the splice connection was bad.
The hose fittings are a pain if you want to use stainless hose between the pump and the master cylinder and the master cylinder and a remote brake fluid reservoir.
Bottom line.....their quality control seems a bit lax, but after all the initial bugs are worked out, the product performs as advertised.
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
