Track Rules last visit
These rules applied on a week day special night where all NHRA rules were not enforced. Several years ago.
----REQUIRED IF RUNNING ON THE DRAG STRIP BY EVERYONE
Drivers license & proof of insurance
Snell SA-2000 or higher approved helmet
Long pants
Long sleeve shirts
Coolant overflow tank no less than 16 ounces
5 point harnesses with 3" Seat belts, shoulder & anti-sub belt
(SFI harness must be dated 2 years or newer if in a full caged roll bar car)
Roll bar (factory bar acceptable)
Securely mounted battery
Tail lights must be lit at the starting line and during the trip down the track
Driveshaft loop required if running slicks
----REQUIRED IF RUNNING UNDER A 12 SECOND, OR OVER A 135 MPH 1/4 MILE
SFI approved bellhousing
SFI approved flywheel & clutch
Arm restraint straps (recommended even if not running under 12 seconds!)
----REQUIRED IF RUNNING UNDER A 11 SECOND, OR OVER A 135 MPH 1/4 MILE
SFI approved harmonic damper
Protective clothing
Roll cage
Transmission shield
I don't want to rain on the parade, but.... NHRA rules are the reason Firebird won't let us run there.
AZ Bob
