Thread: Sidepipe rattle
Old 03-04-2010, 10:13 AM
Messinger Messinger is offline
Default Side pipe rattle
Do not know if you have already figured this out or not. Same thing happened to me. I cut the pipe at the rear of the baffle (where it was welded) and found the baffle (it looks like an auger bit) had broken loose from where it was welded on one end. I ended up replacing the entire baffle with a Stainless Steel glasspack I found at Summit. I wanted to tone down the sound a little. I could have just re-welded the baffle and then re-welded the tip back on.
