Old 03-07-2010, 04:19 PM
DAVID GAGNARD's Avatar
anybody every restrict the the front 1/2" oil hole to the front main?
this is a production block btw.
I don't, I prefer full oil/pressure to the cam bearings and lifters, but I do use restricted push rods....Summit/Jegs and others have them,but you have to call and ask for them, there are not in the catalog.....
Basically the hole thru the pushrod is of a smaller diameter allowing less oil to the rocker arms.very helpful when using a high volume oil pump.......
Even with the restricted pushrods, when priming the engine with the valve covers off, there is plenty of oil going to the top end.......
David
DAVID GAGNARD
