Old 03-08-2010, 05:21 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Originally Posted by CHANMADD View Post
The oil restrictor hole is normally 0.060"
You should only use the restrictors if you have solid lifters......but you knew that!!☺
John
yup on the solid rollers. i am talking about the cam bearing oiling tunnels off the main saddles. .060 sounds right, i think it is a 5/16-18 set screw they use.
i am going to leave the oil feed to the lifter galley alone and contemplating a hardline off the rear branch to each galley halfway down the block. i had a fps engine they had done this to for hyd lifters and kind of like the idea.
did a www search and there are a few other oiling system mods people are using, good info out there if a person can sift through it all.
