Old 03-08-2010, 03:55 PM
rockman539 rockman539 is offline
Cobra Make, Engine: classic roadster II 351 win
Default Classic Roadster body mounts
:What is the best way to mount the body on a calssic roadster ? Where do you start? I have the body laying on the frame, defroster duct against rear bar of hoop. I measured from the upper a-arm mount to gel coat line of front fenders. 10.5 inches. But, now the marks for the bumper bolts are off on the right side. I have to raise it and shim about 5/16 up for this to line up with the holes in the frame. The left side is fine. For side to side, I have to pry the front end to the right about 1/4 inch and shim. Is this normal ? I don't want to wind up with a twisted body.
If this is alright, do I do the floor by the doors next? I cut the hinge mount plates off the hoop as DV suggested. With the body pulled down, I will align door and weld plate in. Is this right? Any help would be appreciated.
