Old 03-08-2010, 05:43 PM
wreckerboy wreckerboy is offline
Cobra Make, Engine: ClassicRoadster 4.6 supercharged
Put the rubber on the frame where classic tells you pull the body to the cowl bar and i start in the front centering the wheels in the wheel wells take a look at bumper mtg,s at the loop to see if the holes that you will drill later are close this is where you will noif off side to side more also right side wheel will never center perfect just clamp the front then go just inside the door opening put self drilling bolt down thru take measurement at rear side to side put 2nd selftaper in door opening then start on the doorsadjust rear body up or down as needed normally doesn,t move much
